headgasket parts
Posted: Sat Dec 01, 2007 6:14 pm
by rover220
hi guys
whats needed to do the job properly?
ive ordered so far, the hg, base and exhaust gaskets.
anything else needed on top of this?
Re: headgasket parts
Posted: Sun Dec 02, 2007 8:48 am
new camchain? been a while since i've done this but dont you have to split the camchain to get the heag off?
Posted: Sun Dec 02, 2007 10:19 am
If the chain gets stuck at the bottom you can always file away the bit of casing to get it through, its a mod thats been done before.
Posted: Sun Dec 02, 2007 11:18 am
by Northern ANdy
no the camchain wont need splitting
Posted: Sun Dec 02, 2007 11:48 am
by rover220
so i dont need any other parts then other than what ive listed?
Posted: Sun Dec 02, 2007 11:52 am
a head gasket, you havent listed that
Can you re-use the head bolts? Or are they re-usable?
Posted: Sun Dec 02, 2007 11:55 am
by rover220
RobB wrote:a head gasket, you havent listed that
im assuming you can reuse them, doesnt mention anything about them in the manual.
and yes, i have listed headgasket.
Posted: Sun Dec 02, 2007 12:15 pm
you have havent you, why i took hg as something to do with a compression tester i dont know, isnt hg something to do with measuring the hydrogen content in something like battery fluid?
Posted: Sun Dec 02, 2007 2:38 pm
by rover220
RobB wrote:you have havent you, why i took hg as something to do with a compression tester i dont know, isnt hg something to do with measuring the hydrogen content in something like battery fluid?
im not sure lol, "in/hg" is a measurement of pressure if that means anything.
Posted: Sun Dec 02, 2007 6:52 pm
by rover220
ive been lookng at the manual and to replace the base gasket, it looks like im gonna have to remove pistons/rings and refit... is this correct?
Posted: Sun Dec 02, 2007 10:11 pm
Yeah defo need to do that, no other way to get the base gasket on because the locating studs for the block pass through it.
Posted: Mon Dec 03, 2007 9:13 am
i read hg as head gasket
