Please help a newbe
T.Rigger
My Bike: ZXR400 L1
Please help a newbe
Post by T.Rigger »
Hello, I'm hoping someone can help.
How on earth am I meant to know what tyre pressures I should be running? I can't find the info anywhere and my biker mates just say they leave it up to the garage.
I've a L1, running Michelin Pilot Roads, they've done 11k miles but still got heaps of tread left. Been fine all summer but now the cold mornings are creeping in they feel a little.... floaty.
Thanks in advance.
Re: Please help a newbe
5 views and not one response...............so thats 6 of you that dont know your tyre pressures
:ffs
thomp1983
My Bike: zxr 400 l3
Post by thomp1983 »
http://www.zxrworld.co.uk/zxr400/lmodel.html
and i run mine at 32/36
chris
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 »
cargo wrote:5 views and not one response...............so thats 6 of you that dont know your tyre pressures
:ffs
nice of you to chip in with a constructive post, really helped the OP there.
i run my pirellis 32/36 as well...
I'd have given him the answer he needed soon enough..................he's ridden the bike all summer without checking his tyre presures one more night would have not hurt him
My point still stands when I posted 5 people viewed his question and none either knew the right pressures or bothered to reply
Modern tyres run at lower pressures.................32/36 is the orginal pressures reccommended by Kawasaki but I'd be very surprised if 32/36 is correct for modern tyres
I use 30/31 on mine................the current reccommend pressures for my tyres ranges from 27 to 31 for the rear and 31 for front
there is a rear Bridgestone that runs at 26psi..................
I'd check with the tyre manufacturer they will know what the tyre pressures should be
Also pressure guages are notoriously inaccurate.................so buy a good one and use it exclusively.
Do NOT rely on some hooky garage or mechanic to get it right
Now thats a full and comprehensive answer
cookiesol
My Bike: ZXR 400 L7
Post by cookiesol »
cargo wrote:I'd have given him the answer he needed soon enough..................he's ridden the bike all summer without checking his tyre presures one more night would have not hurt him
goodpost
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 »
cargo wrote:Modern tyres run at lower pressures.................32/36 is the orginal pressures reccommended by Kawasaki but I'd be very surprised if 32/36 is correct for modern tyres
pirelli website states 2.25bar front, 2.5bar rear for rosso II's...thats 32/36psi.
And your point is ?
FYI
I dont use Rosso II................... not fit for my purpose
Robbie
My Bike: zxr400
Post by Robbie »
Remember and use pure nitrogen when blowing up your tyres.Its much better makes your bike lighter and is worth an extra 5bhp.
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 »
And your point is ?
FYI
point being its a modern tyre...you said modern tyres would not use 32/36...yet it does...sweeping statements and all that.
I did not say that modern tyres would not use 32/36
I did say I would be surprised if modern tyres used 32/36
And as it happens the tyres I use run in the range I described
Deswilkie
My Bike: ZXR400L, Trumpet 675
Post by Deswilkie »
Robbie wrote:Remember and use pure nitrogen when blowing up your tyres.Its much better makes your bike lighter and is worth an extra 5bhp.
I've heard that too.... The inertia required to start rolling with standard weight air acts as a drag so replacing with nitrogen helps the bike accelerate, brake and turn quicker. Most effective if the tyres really cold though.
Robbie
My Bike: zxr400
Post by Robbie »
Also remember leave off your valve caps off as the weight saved will make the bike quicker.
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 »
the amount of "extra" air in the tyre probably equates to ~50g if that...given that even a carbon fibre spoked tyre might be 5kg, the air content is at most 1%, and air is 71% nitrogen already...not gonna give you 5bhp...
the reason for using pure nitrogen is that the expansion is more controlled under temperature...although it will leak out of the tyre faster than "standard" air as molecules of N2 are physically smaller than O2 due to a triple bond being slightly shorter than a double bond in O2, also nitrogen has a smaller van der waals diameter.
Robbie
My Bike: zxr400
Post by Robbie »
another tip for ya.Only buy Pirelli tyres as they are much lighter than the other brands.Got to be worth 2 bhp.
Remember all these tips will make your bike quicker..
