cleaning oil strainer screen
ross46
- Restricted
- My Bike: zxr 400 l6
How often do you need to clean the internal oil filter? Is it a good idea?
Re: cleaning oil strainer screen
needs cleaning if its completely blocked only, if not i would leave it, or at least pick some bits off it. the oil filter is there to fiter oil going to anywhere critical
ross46
- Restricted
Just saw one on eBay and searched where it was in the engine and thought that everybody replaces the external oil filter but not the internal one, might take mine out during the rebuild just to see how bad it gets
mine of the fzr had a fair bit of crap attached to it, but it was in no way enough to compromise the function of the oil pump, ive cleaned it as im doing the rebuild, but if not i would have picked some bits off it that were on the outside of the filter, and left it like that.
incidentally i got mine looking like this - the zxr one might be similar - the gauze at the front "is" detachable, it sort of clips onto the base.
Nope that looks nothing like the internal oil pick up filter in a ZXR400.
From memory the internal filter is not mentioned in the routine service schedule .....................clean it if your ever in there. I'd have a look if you suspect internal damage of some kind that hasn't made itself evident elsewhere.
the zxr internal oil filter looks like a cone with a mesh on it, i couldnt remember if it was removable or not.
rmkd177
I would think its probably too late by then and will have done severe damage.banner001 wrote:needs cleaning if its completely blocked only,
R.Middleton
