Definitely headgasket?
neil_1821
My Bike: ZXR 750 & ZXR 400
Post by neil_1821 »
So all the symptoms were there that my head gasket had gone on the 400 even though the previous owner had rebuilt it and done zero miles on the engine.
I was getting white smoke out the exhaust when trying to start it, coolant system was over pressurising, creamy white on the oil glass and oil filler cap and oil level had risen.
I've stripped the head off today and the cylinders did have some water in, although I can't see that the headgasket has definitely failed. The only signs I can see is where the black has come off and is exposing the silver but is that proof enough that it is the headgasket?
kawazonkey
My Bike: Kawasaki zxr400
Re: Definitely headgasket?
Post by kawazonkey »
You can never be 100% sure the head gasket has gone on anything...could be a cracked block or any number of issues. Since you've gone this far I'd suggest doing the head gasket anyway and see what happens.
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
My guess would be the head needs skimming.
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 »
CaNsA wrote:My guess would be the head needs skimming.
+1, or at the very least checked for straightness/level, especially as water has gotten in, if its leaked with a new gasket, and the head was installed and torqued correctly in the proper criss-cross pattern its likely that there is enough of a gap for coolant to be forced in to the cylinder. you might wanna get the cylinders checked as well for damage/straightness/level.
Madderz
My Bike: 1992 Kawasaki ZXR400
Post by Madderz »
+1 Personally I'd start by checking the head with an engineered straight edge and torch/feeler gauges. Diagonally from each corner, horizontally through all 4 cyclinders/chambers, middle, top and bottom. Then just to be safe i'd go vertically across all 4 cyclinders/chambers. If you can see light or get your smallest feeler gauge through that's probably also where your coolant is getting through.
If that's the case. Get her skimmed.
He who dares, Wins.
