ZXR400 "How do I..."
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 »
Hi all, am intending this to be a growing list of how to perform things on your bike, with clear pictures and well written guides. If you think something existing should go in here please provide a link to the page, please also keep adding things that we dont currently have pictures for and ill try and sort something out as i start to put my bike back together :D
Bike Identification
ZXR400 H, J, L and M models, all years listed
Manuals for H model, L model supplement, H1 Kit racing modifications, L model owners handboox, L9 buyers guide
Microfiche for H1 and J1, L1-L3, L4-L8, ZX-4G
Fuel system
How do i remove the fuel tank and airbox to change the air filter or get access to the carbs
How a ZXR400 CV Carb Works
How to strip and clean your carbs
How to adjust your carbs jets/float heights/pilot screws
Carb balancing
Cooling system
Engine and transmission
How to fit a new camchain and set the timing correctly
How to check your valve clearances and change shims
Clutch
Final drive
Wheels/tyres
Brakes
Rear master cylinder rebuild
Suspension
Steering
Exhaust
Frame
Electrics
Diagnosing charging faults
Full colour non-Italian H1-2 wiring diagram
Full colour UK L1-4 wiring diagram and race-loom mods
Full colour UK L5-8 wiring diagram
1994 Fuse box disassembly
im thinking as a starting point we need the following:
-how to change bulbs, so front, indicators, rears, instrument bulbs
-fork seals, oil and air gap
-wheel bearings
-brake pads front and rear
-brake bleeding from wet as well as dry/new
-how to setup the bike for your body position
-front/rear sprockets and chain
-clutch plates
-brake disks front and rear
Miles
My Bike: ZXR 400 L3
Re: ZXR400 "How do I..."
Post by Miles »
Hey banner chuck this in the carb section
viewtopic.php?f=115&t=15099&hilit=Float+height
I know it crosses over with your guide alit but it does go into setup of float height etc
Miles
My Bike: ZXR 400 L3
Post by Miles »
Brilliant guide on checking shims
viewtopic.php?t=8002
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 »
good finds, both added
