backfiring!!!
zxrtbone
backfiring!!!
Post by zxrtbone »
hey dudes,my bike seems to have lost some of its performance lately and the last couple of times i've started it it backfired,well i think it backfired there was a loud pop!!! i've had the air box off the other day when i was checking the HT leads but i've had the airbox off plenty of times and there's never been a problem after i'd refitted it,any ideas? :smt017
sure you haven't pulled one of the leads off?
zxrtbone
Post by zxrtbone »
dunno i'll check,would that make it backfire?
HT leads on the wrong way??????
if its loose it might as the spark may not be soo bright to burn all the fuel goin through.
zxrtbone
Post by zxrtbone »
had a look at the HT leads and the far left one is a bit loose where it screws into the top of the plug cap, i'd say i need a new set of leads,also i noticed that the far left and far right spark plug caps do not push down as far as the middle two,i've tried to push them down but they wont budge,new plugs and leads then?
zxrtbone
Post by zxrtbone »
does anybody know if a H model ignition coil and HT leads will work on my L model.
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
Just replaced the leads on my 94 bike. Mainly becuase I prefer the flexibilty of silicone rubber to the old pvc ones, glad I did it though becuase I hae never seen such a many set of ends on HT leads. You can get HT cable cheapy so I would do that first, The coils do fit though
Andy
zxrtbone
Post by zxrtbone »
so my L model will run sound with H model ignition coil and HT leads???
diesel
My Bike: Zx7r
Post by diesel »
check the workshop manuals and microficjes on this site mate. that should tell you
Quicker Than Yngwie
zxrtbone
Post by zxrtbone »
I've found out that they are the same,had a right result off of e-bay,check out the free for all forum i've left a message on there,thanks dudes.
diesel
My Bike: Zx7r
Post by diesel »
glad you got sorted :smt003
Quicker Than Yngwie
