Anchor Kawasaki Centre
Guest
Address:
99 Wellingborough Road Finedon
NN9 5LG Wellingborough
tel. 01933 680274
fax. 01933 681664
Address:
tel. 01933 680274
fax. 01933 681664
NickT22
Anchor Kawasaki
Good for parts and information but watch the workshop prices - quoted me minimum 7 hours to remove and inspect my engine, plus parts cost, even if the problem may only be the cam chain tensioner!
Also charged a mate £1500 for a full service and battery change/charge circuit fix for a H2 model 750! When he picked it up they told him all ok but will need front brakes at £750 plus fitting time and battery still does not hold charge!
Dissapointing!
Dissapointing!
Bikerz
lol. i was quoted 100 notes to check valves, balence carbs and check cam chain. im thinking thats a bargin. they even said im afriad shims are 5 quid each tho if any need new ones, but at 100 quid for rest im not too woried
master
- My Bike: ninja250r
Re: Anchor Kawasaki Centre
anchor kawasaki rip-off so is corby kawasaki . bloke in corby very cheap will post his mobile number if he says its ok , fantastic mechanic and very cheap and he's a biker ..gsx1000
dunno bout Anchor being a rip off? they were extremely helpful when i bought my first zxr400, trevor in stores especially!!
terescova
How do I prevent a drywall anchor from spinning? I installed a crappy wal-mart shelf in the bathroom and upon putting the last screw in, the anchor started to spin in the whole. This thing is a pain in the *** (the manufacturer obviously has zero understanding of basic physics.....like a solid object cannot pass thru another solid object..), and I really don't want to remove it and drill new holes.
__________________________
external keyword tool ~ keyworddiscovery.com ~ keycompete.com ~ compete.com ~ webmasterworld.com
- cdstirland81
- My Bike: ZXR400H1 and proud!
terescova wrote:How do I prevent a drywall anchor from spinning? I installed a crappy wal-mart shelf in the bathroom and upon putting the last screw in, the anchor started to spin in the whole. This thing is a pain in the *** (the manufacturer obviously has zero understanding of basic physics.....like a solid object cannot pass thru another solid object..), and I really don't want to remove it and drill new holes.
what is the weather like on your planet?
incidentally, get down the diy shop and get specific studwall/dry wall rawlplugs and start again?
- jake
hahaterescova wrote:How do I prevent a drywall anchor from spinning? I installed a crappy wal-mart shelf in the bathroom and upon putting the last screw in, the anchor started to spin in the whole. This thing is a pain in the *** (the manufacturer obviously has zero understanding of basic physics.....like a solid object cannot pass thru another solid object..), and I really don't want to remove it and drill new holes.
put down the screwdriver and walk away before you hurt yourself.
Geffro
- My Bike: ZXR400 L1 trackbike
lol Are you on the right website? And to answer your question, if the dry wall fixings/spirals ain't working get some toggles/umbrella's!terescova wrote:How do I prevent a drywall anchor from spinning? I installed a crappy wal-mart shelf in the bathroom and upon putting the last screw in, the anchor started to spin in the whole. This thing is a pain in the *** (the manufacturer obviously has zero understanding of basic physics.....like a solid object cannot pass thru another solid object..), and I really don't want to remove it and drill new holes.
Lachie Innes #99
will#224
- My Bike: L1 racer
That is the funniest post ever on here!
Well done!
- rickyt28
- My Bike: ZXR400 L5
But seriously, cut a hole in the plasterboard, slip a piece of timber in behind where you want to screw your brackets, and screw through the plasterboard and into the timber. Then patch up the hole. That is the best way to get a decent fixing, especially with a shelf that is going to be loaded with heavy items
lol
- rickyt28
Its a bot that init. How did they manage to log on?
