rattly engine?
wee des
rattly engine?
do you know if they are prone to being rattly engines as mine sounds very cam-chain noisey but goes away when i open the throttle but sounds rough when i shut the throttle off...
Re: WHAT IS IT H or L1.
whats it like when you pull the clutch in?
wee des
Its not the clutch thats a different sound mate its sounds more like a cam-chain rattle sorry i cant explain better..
What hes trying to say is, does it sound any different whent he clutch is pulled in? As the ZXR is known for its noisy clutches. If it goes quiet the noise is more likely to be the clutch than the cam chain. If its still just as noisy then you are probably right in that it may be the cam chain, in which case you will need to replace the tensioner.
wee des
Cheers guys pulling the clutch in does not change the sound there is a slight knocking from the clutch basket, were is the best place to get a tensioner..
in that case it could be the tensioner then. Check it first and see where the tensioner is sitting, if it fully adjusted then it'll need doing.
wee des
Cheers mate will check that when off work...
- carsounds_dan
Re: rattly engine?
try cradleys, either that or try one of the brakers online.
...i know, it's great
Re: rattly engine?
If you have a noisy cam chain it could well be that the chain needs replaced and the tensioner is fine .
Just because the tensioner is at it's full extenion doesn't mean that it is faulty.
