Removing base gasket
zxr4000
My Bike: zxr400
Post by zxr4000 »
Hi all,
I've heared some racers have removed their base gasket and skimmed the cylinder head. My question is how the cylinder base is sealed without this base gasket?
Roy
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Re: Removing base gasket
Post by lewisdale »
sealant
good old hermatite i think does the trick :)
noelb
My Bike: ZXR4H , H'Berg , BMW R12S
Post by noelb »
As there are oil galleries thru the split I try to use some of the new fancy sealants, and very sparingly. The last one I did, I used kick-ass loctite (910 I think) and never had any bother but will be using Dirko this time - any decent motor factor should have it. I seems to be the modern car equivilent of yamabond. Thinking of it - yamabond would probably do the job as well!
Noel B.
zxr4000
My Bike: zxr400
Post by zxr4000 »
Thanks for the hints guys..
zxr4000
My Bike: zxr400
Post by zxr4000 »
Hi All,
I just heared that removeing the base gasket could damage the piston rings because the barrels are lowered and the rings touch the upper part of the barrel that hasn't been used (ran in) ever before. Sound plausible as my engine is from 1998 with appox 15000mi..
Anyone removed the gasket on a used engine or does it rquire the barrels to be honed on a used engine?
Roy
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
good point mate but surely you should have youre barrels honed anyway if your removing the top end, even if the same piston and rings are going back, this is what ive always been told from a early age on car and bike engines, ideally i would replace the rings at the same time too
