removing pistons from calipers
hollingsbee#54
My front brakes are binding quite alot so ive decided to clean the calipers out. I know its a bit of a rookie question but whats the proper way to remove the pistons from the calipers. Also can anyone think of another reason why they might be binding so much.
Rob Hollingsbee Superbike 400
zxr400er
hollingsbee#54
You can use an air compressor to push them out but dont get your finger in the way! This happened to a friend of mine, needless to say it F***ing hurt!
Have you tried cleaning the pistons first? You can just push them out a few millimetres and clean em with some brake cleaner, then see how they are after that. Its only a half hour job and could save you the hassle of a rebuild.
They might be binding because the seals have had it, they may have got contaminated with something and caused the seals to swell. Or they could just be old. Youll probably have to change them anyway when you get em apart.
hollingsbee#54
400hnutter
I dont know if this link will help but try this site for cheap parts they saved me a packet when i did mine!
http://www.wemoto.co.uk
who needs knees when you have toes.
