master cylinder?
missinNZ1
My Bike: zxr400 L2 uk mod
master cylinder?
Post by missinNZ1 »
looking at front upgrade and am wondering what "19x20" size is and more to point what is correct for zxr 400. cant find a mention of this number in manual.
Re: master cylinder?
Post by SOILZX »
I'm not 100% sure, but i believe "19x20" means the bore of the cylinder (being 19mm) and the lever ratio (20), which on some models can be adjustable (18/20).
I believe the standard m/c has a 14mm bore? (again, not 100% sure). As for upgrades, it depends what its use will be and what calipers your using, i know a few people on here upgrade to a ZX7R m/c.
Obviously, the bigger bore the m/c, the more fluid it can shift, giving a better feel and stronger performance. I'm looking at upgrade options meself and to be fair, looks like i'm gona go with the ZX7R cylinder (just cant stretch to a Brembo :smt010 )
Hope this helps
I've got a ZX10R radial master cylinder on one of my bikes...................slightly tricky to fit cos the hoses and banjo bolt end up very close to the fork leg and it took a bit of fiddling round with the switch gear.......................... but works a treat with standard ZXR400 calipers
Post by SOILZX »
Must admit i've thought about using a ZX10 m/c, thats another option if one comes along cheep enough. I thought about the 7R one mainly because of how cheep they are, can be had for like £30 on egay, where as the ZX10 eem to be nearer the £100 mark. Are the ZX10 cylinders all the same, or is there is 1 from a particular model that you would recomend?
SOILZX wrote:Must admit i've thought about using a ZX10 m/c, thats another option if one comes along cheep enough. I thought about the 7R one mainly because of how cheep they are, can be had for like £30 on egay, where as the ZX10 eem to be nearer the £100 mark. Are the ZX10 cylinders all the same, or is there is 1 from a particular model that you would recomend?
I've no idea what model ZX10R it came off I just saw it on ebay and bought it...................I think the problem with one off the 750 might just be that it would be older and have more wear/miles on it....................
Funnily enough I have a friend who raced a ZX10R and he hated the standard master cylinder and fitted a Brembo one.....................he said the seals leaked/passed and left him with no brake..........................................................I've had no such problem
Post by SOILZX »
I have a mate who has a ZX10 on the road and he hated it aswell, so binned it favour of a Brembo, have asked if i can take it off his hands, but he wants to keep it for when he gets rid of the bike :smt009
If i can find 1 cheep enough, i think this could be a better option, as you say a 7r cylinder is more likey to have wear and tear, lets see what santa can fit through the letter box winks
don't think the brembo will fit cos it hits the clocks, what's wrong with the original? zxr400 brakes IMO have always been mint!
Post by SOILZX »
To be fair, the brakes on my first 1 seemed ok, the brakes on the 1 i've got now are shite!! I came across some freshly rebuilt 6 pots cheep, so thought i'd give them go (and i love the look of 6 pots!!)
6 pots are shite mate!
Post by SOILZX »
Had a set on my old gixxer srad and after a rebuild they were sound. I'll be keeping the standard calipers so if there shite, i'll rebuild the originals and slap them back on. Just see how it goes eh.
Funnily enough I have a a standard master cylinder and caliper set up that sits in a box cos they are crap and all attempts to sort them have failed..................strange
bendog66
Post by bendog66 »
masterofinsanity wrote:6 pots are shite mate!
They really aren't. They're a bit tricky to bleed properly, which is why people give up with them and blame the calipers...
well i have 6 pots on my TL and they have been complety rebuilt several times and are still crap, new m/c rebuild kit is next on the list.
Wabby
My Bike: ZXR400
Post by Wabby »
If you want better brakes, just bolt on some gixxer 6 k1/k2/k3 4 pots - absolutely AWESOME!
missinNZ1
Post by missinNZ1 »
forgot id even posted this and just had a read through, nicely poached!!!
am still looking around.
