L wheel on h bike more info needed plz
newnut
Post by newnut »
Hi there, i have an l model wheel for my H model forks, can any1 tell me exactly how much i need to take off the spacer to make it fit?
Also will L model calipers be a direct fit on h forks to allow for L model discs? please help asap guys as i need to get this bike built up for the summer!!!
Re: L wheel on h bike more info needed plz
calipers are interchangeable, H meant to be slightly better due to biger pad.. debateable, either will work with either disc, its the forks that are disc size specific (if using standard calipers) as the mounts are positioned differently on the lowers.
I cut down a spacer once to fit an L wheel in H forks.. cant remember how much.. dont think i even measured it.. just ground it back a few mill at a time till it all fitted nicely.. sorry that's not much help really is it .. 3-4mm ish. winks
If its in good nick and your around the northwest, i will swap you a H front wheel (black, good condition.
got discs aplenty too if needed
newnut
Post by newnut »
that is a help, thanks a lot. you say the mounting points are different on the lowers which effects disc size, so if i go with L wheel, L calipers, just to clarify i'll need what model disc?
oh and i would swap, but im just south of reading, so too far, sorry.
if using standard calipers (either H or L) the discs must match the forks, (ie H on H, L on L)
put L discs in H forks and the caliper body will foul the discs whether they are L or H calipers
put H discs in L forks and the pads will partly miss the disc
newnut
Post by newnut »
ok i get it, thank you so much!
