Quick question, as its been a while, does the rad need to be removed to get the downpipes off?
Downpipes - Removal of.
- CaNsA
- My Bike: ZX6R F1
Re: Downpipes - Removal of.
never tried it might be possible
but certainly access will be much easier with the rad off...............if it's a road bike then the nuts will be tight and maybe even rusted solid so good access will help.............................
- CaNsA
- My Bike: ZX6R F1
Cheers dude.
- extonyg
- My Bike: zxr 400 L1 uk
i have done it with rad in place but as cargo said they can be tight and fiddley but it is possible if not just lower it down if you dont want to drain the coolant.
Just undo the mounts and use a 6mm ratchet with small extension - plenty room to dish your knuckles on the fins
BTW, have swapped the system on my bike about 10 times now and never removed rad just the above and all knuckles are still here I think
MM!
MM!
- Tirpitz
- My Bike: Kawasaki ZXR400L4
If the nuts are tight you might want to stop and apply some heat before continuing. A cheapo blowlamp will do. Cos if you snap them off a simple job becomes a whole load of hassle
When you put them back on do yourself (and any subsequent owner) a favour and put a smear of copper grease on the stud. Easy peasy next time then.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
- CaNsA
- My Bike: ZX6R F1
Cheers for the refresh guys,
Martin........... there had better be copper grease on these studs!
- Tirpitz
........otherwise he'll ban you off the forumCaNsA wrote:Cheers for the refresh guys,
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
