stock size front tyre?
grey zxr400l
Post by grey zxr400l »
is anyone using a 120x60 size in the owners manual? reading the posts appears 120x70 thats nearly 1"taller is widely prefered.also is the tool tray useable with a SP solo style seat maybe from underneth?
standard is 120/60 thats what i have anyway.
As for the tool tray, do you have a proper SP seat unit where the bum pad undoes with a key? If you have you should be able to get the tool kit in and out. I used to stick the removable baffle for my exhaust in there.
If youve got an aftermarket type then itll be a case of taking the whole seat unit off every time you need it.
