Hi guys, new here and first post.. Bought a 90 h model last month.. Just put in new rings and got her running last night!!
Anyway, did some clearance checks and seems quite worn..
Exhaust were anything between 0.18-0.26mm, intake 0.18-0.22.
Very few were within spec.. Can I customize a set based on my numbers?
Thanks! Too bad I'm 6-2! This thing is tiny..
FYI took these readings cold..
Sent from my SM-G900M using Tapatalk
Shim questions zxr400
- jamesgoodfella
- My Bike: ZXR400 H1 + CB350K2
Re: Shim questions zxr400
Won't do that for you. If you searched you'd have found a very detailed guide on how to do this
viewtopic.php?t=8002
masterofinsanity wrote:or use a Duplo brick
