Need help- Headlight problem!
Dolts
Post by Dolts »
Ok, the problem is, everything works fine untill you put main beam on or flash, the high beam stays on untill you switch off the ignition!
I have taken the dimmer/ pass switch apart and cleaned all the terminals etc, and i have swapped the relay and it hasnt cured it! you can hear the relay click on but not off?
Please help!
check your earths and battery mate believe me!
Long
Post by Long »
Sounds like a short or break in the wire that sends the signal back to the relay. Check the loom where it meets metal for wear. If you can identify the wire that returns the signal to the relay, then trace that wire looking for same.
sloweracing
Post by sloweracing »
Welcome to the best forum for the ZXR
http://www.sloweracing.co.uk
Powered by
http://www.zxrworld.co.uk
Dolts
Post by Dolts »
wahay! sorted it, took the relay off, gave it a clonk, put it back and it all works! :smt003
sloweracing
Job done :smt003
Long
Post by Long »
Yeah, that was my next bit of advice...smack it with a hammer. :smt003
