Accelerator Stuck Open
insurerman
Post by insurerman »
Hi all, been enjoying my bike with the nice weather over the last few days now the new engine is in, thing is the accelerator has stuck open for some reason. Haven't had time yet to find out the problem as i'm at work but do you think it is something simple like one of the cables has come off the carbs and it's not returning properly? Any ideas?
sounds like your accellerator cable could of frayed and stuck in the outer casing, hence the reason for the deccellerator cable so to all those that are thinking of removing it, it is there for a reason!
CarneyUK
Post by CarneyUK »
As Master said. The easiest way to check before taking the tank and everything off is to open up the the throttle housing (just 2 screws behind the front brake lever) and pull the 2 cables. If the accelerator cable (one with the black square housing) comes out then you know what it is.
insurerman
Cheers Baz, u are a god :smt003 :smt003 :smt003
i spent 16 years of my life making & selling control cables mate :smt003
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
i spent 16 seconds removing one, have never looked back
Andy
diesel
My Bike: Zx7r
Post by diesel »
throttle stuck open eh. can i borrow your bike ;)
Quicker Than Yngwie
deviant
Post by deviant »
load of wd40 down the cable can do the trick.
insurerman
Well I can you wot it woz peeps! The valves on second piston had smashed into the piston (that woz wot the tapping woz baz!) and completely mashed that up to and the bits of metal were pushed up into the pot and up into the carbs causing it to jam open and revving the hell outta my motor. Ah ha! There we go, not much luck with my engines at the moment i'm afraid!! Anyone selling a complete head on here at all? Don't need the cams. Managed to change the piston head over, thank god it never damaged the con rod eh? :smt003
deviant
Post by deviant »
deviant wrote:load of wd40 down the cable can do the trick.
but probably not in this case :smt002
ouch.
Northern ANdy
give this man in Leeds a ring
07743 998366
I bought an engine from him, If hes got a head im pretty sure it will be for sale
Andy
