braided brake lines
ratbag56
- My Bike: zxr400 / 636
braided brake lines
i have a set of race brake lines since i have fitted them the brakes dont feel as good, i have bleed them alot and have a new set of pads wit good calipers!i was wondering if it is the way i have connected my pipes! how has every else fitted them?
Re: braided brake lines
Theres two fitments, the 3 line and two line. The three line uses a short pipe to goto the splitter that sits in between the forks and then two longer lines split off that to each caliper.
Then theres the two line, which is simply two lines from the master cylinder straight to each caliper which uses a longer banjo bolt to accomodate both lines.
The two line is best apparently for reasons unknown to me. Have you considered the master cylinder? It should be rock hard when you pull the lever back far enough and not spongy. I have a brake bleeding tool which sucks the fluid through rather than pumping the lever etc and takes about 30 mins to do the whole bike, if you want i can help you re-bleed them, long as the reservoir is kept topped up theres no chance of any air getting in.
2 lines are alot easy to bleed i find, plus why have the spliter when you can run to lines direct? im a firm beliver in KEEP IT SIMPLE!
ratbag56
have sorted it got the hump so i completly bleed the system again is better now the more i use it thanks guys
sic1181
yeah been havin lots of trouble settin up my braided hoses, will try the 2 way system see if it helps
Ghost Rider Is God!
