carburetta problems
bleddynzxr400
carburetta problems
Post by bleddynzxr400 »
hi guys i need to pick your brains about my bikes problem. before i changed the original engine it was not running tidy it was over heating and was struggling to pull off it would just stall.ive recently found out the thermostat on my original engine wasnt working. and the fact that it had no oil cooler could have been causing the over heating. now the pulling off problem. ive fitted the new engine and it fired up first time ticks over tidy but as soon as i try to rev it a bit higher it seems to die again same as the first engine but without overheating i was wondering if theres a problem with fueling or carbs need balencing. would a eletrical problem give any of these problems im a bit confused as to whats going on realy because ive changed the engine and solved one of two problems as it stands ive spent close £1100.00 and its still basically a non runner any advice would be helpful
thanks
bledd
Re: carburetta problems
Have you checked the side stand switch is connected properly?
bleddynzxr400
rite ive checked the side stand switch and its not connected to anything and i cant find any other blocks to connect it to anyone know where it joins. plus its not only when i try to pull off that it dies but its when you rev it when its in neutal
bledd
Should be a wiring block round by the sprocket cover. Not sure if it will cause it to cut out revving it in neutral but its a start. Out of interest did you use the same carbs as on the old engine?
bleddynzxr400
it looks like the sidestand switch has been bye passed and yes i am useing the original carbs i think they must be gummed up with old fuel as the bike has been standing for nearly 7 months would squirting carb cleaner in them help or should i strip and clean them
bledd
Ummmm, you can try squirting carb cleaner in but dont think it works lke that cos it will contaminate the fuel. Probably best to strip and clean them. Once you done that dont forget to run some redex through, thatll clean up nicely too :D
rover220
My Bike: zx7r p6
Post by rover220 »
redex straight into the fuel tank? how much?
Yeah mix it in with the fuel. It says on the back how much to put in for every litre or so. Personally i fill the tank brim full and pop in one of the small bottles you can buy at halfords for 99p. I think they are 50ml, so roughly 50ml for a full tank i guess then. That should clean them out and give your entire fuel system a clean.
:smt001
bleddynzxr400
rite im having the carbs cleaned and balanced later this week so that should hopefully cure my problem i would have put redex in the tank but my tank is at the paintshop being done along with all the other body panels.then i have to strip the discs of the wheels and get them sprayed then its job done
bledd
bleddynzxr400
rite ive had my bike back today and its running perfect now. the carbs where the problem they where realy gunked up and most of the jets where knackered so they have all been replaced i also had a new fuel filter fitted and a new throttle cable .the guy who done this for me also said there where no rattles or any other strange noises comming from the engine witch is good.and my tank and panels wil be ready to pick up on monday so for now im happy :smt002
bledd
nice one mate, all systems go then! :smt001
bleddynzxr400
yes rob cant wait now mate it sounded lovely with the scorpian can on it plus the welding is not blowing on the downpipes i just need a few qid to finnish it off any body wanna buy my spare engine.
bledd
