hi guys.
have had the carbs off and completely drained/cleaned etcetc. have refitted today with new fuel filter (bigger than oe one...is that a problem?)
i dont seem to be getting much fuel into the filter, when cranking i get the odd burst and the filter fills some of the way then dissappears. i guess this means the carb bowls are filling slowly?? how long/how much cranking is required to get th system full/ primed???
any tips appreciated.
ta
HELP please!! carb/fuel issue
rover220
- My Bike: zx7r p6
Re: HELP please!! carb/fuel issue
Mine took ages from empty, and i was using a car battery!
parby81
- My Bike: ZXR400 L9
quite a while, you gotta fill four float bowls remember and the pipe work from the pump up to the carbs
rover220
- My Bike: zx7r p6
she lives. ran lumpy as for a while but seems to have evened out now.
jsut need to fit tank and panels and i can give it a test!
rover220
- My Bike: zx7r p6
tomzxr400
it always takes ages to start from dry i always start it with the air box off (and the tank turned round and bolted to the rear frame) then squirt a bit of easy start in each carb and it fires up instantly saves the battery from draining
rover220
- My Bike: zx7r p6
