Jets
Re: Jets
i got mine from here
http://motorcycleproducts.co.uk/
£11.63 for a set... they send you 5 so you've got a spare too
they ARE different to stock.. slightly, they are deeper/taller however you put it .. work though.. i've got the 105's in my H1
dynojet will want 100+ for a "kit" which is IIRC, 2 sets of jets.. diff needles, and ..um .. oh, some washers and maybe allen bolts to replace the crosshead ones that hold the float bowls on. waste of money IMO. for the same outlay you could get a dyno run, change the jetting, and another dyno run to confirm its worked
Re: Jets
102's sound about right with a standard airbox.. mine was rich with 105's till we ripped the trumpet off the airbox .. then it went lean, so im going to go larger again .. if it ends up rich i can always make more holes in the airbox
have noticed though that cylinders 2 and 3 seem to be running hotter (the headers are bluing up way more than 1 and 4) so will be trying staggered jetting with 1 and 4 on 107's with 2 and 3 on 110's.
i've come across staggered jetting a few times on zxr's that have been dynoed, so, we'll see ..
Re: Jets
lol, never mind! Cheers for the advice tho. Cant decide wether to stagger them or not myself. Obviouly theres the cooling issue so may just do it to keep things as they were if you see what i mean. So if i was to do that that would make 1 and 4 #102, and 2 and 3 #104, right?
Re: Jets
they go up in steps of 2.5 but they dont label them as such ..
so its,
100
102.5
105
107.5
110
etc etc ..
you could try 100's and 102's, it'll be better than whats in there, and avoid the possibility of going too rich with 102's/105's
a quick power run with A/F readout should only cost ~£25 to give you an idea of which way to go from there.
so its,
100
102.5
105
107.5
110
etc etc ..
Re: Jets
how do you know what size the jets are? are they marked?
Re: Jets
yeah they are Baz, ones int here at the mo are marked on the side.
Yeah i noticed they go up like that and thought perhaps 100 and 102.5's to avoid going rich.
Is it me or will i have to buy 2 sets of jets to do that as they dont seem to sell them individually......
Re: Jets
put it on a dynobenso1982 wrote:hi guys! i'm from Italy! i need the best settings for the dynojet kit stage 1 i have on my zxr400 L1. i also have a k&n air filter and a complete Micron race system exhaust. can you help me? thank you very much! bye!
