CDI units
Karenann
My Bike: zxr400 H1 & 2
CDI units
Post by Karenann »
Hi, just wondering what letter denotes a full power CDI unit for an 'H' model?....I have a letter A on my cdi and someone told me that a letter M is the full power cdi's? Any ideas guys & dolls? Thanks, Karen-Ann x
Yes I'm blonde, but not dimm....;)
rover220
My Bike: zx7r p6
Re: CDI units
Post by rover220 »
m "1332" is full power for an l model which wont fit an h model.
Re: CDI units
yep, L CDI wont fit an H model, you can get round it by using a KMH-MPH converter tho :smt001 That'll let you go more than 110 at least :smt001
Re: CDI units
to get a "speed restrictor free" cdi on an H you need the uk cdi from an L, and the matching loom to make it fire ..
but yeh, kph - mph converter .. lots easier.
Karenann
Re: CDI units
Post by Karenann »
Hi, so what's an 'A' letter cdi for an 'H' model?...restricted or full power? Karen-Ann x
Re: CDI units
theres no "power restriction" just a speed restriction triggered by a sensor in the speedo, once the needle passes 180kph it tells the cdi to activate the rev limiter..
up to 180kph you have full power
hence, fit a kph to mph converter (so the speedo reads in mph) and its all good, because there's no way your bike will do 180mph, so the restriction never kicks in.
afaik H cdi's are marked 21119-1271 or 21119-1270 they perform identically, have 14,500rpm rev limits* (maybe 14,800.. but im not 100% sure, that may just be the SP.. while the "kit" cdi has different advance mapping and a rev limit of 15,200rpm) and are speed restricted to 180kph
its the 21119-* number that matters, colours and letters seem to be of secondary importance.
*you may well be able to get the rev counter reading 15,000 + rpm .. mine (H1) will hit nearly 16,000rpm .. but hook it up to a dyno, and its clock error, H model rev counters are really quite optimistic, L's seem to be more accurate.
Im in the process of putting an L loom and uk spec L cdi on my H1, for no reason other than it will then rev to 14,900rpm.. but its a race bike.
Re: CDI units
btw, you cant just unplug the speedo from the loom to prevent the 180kph restriction kicking in .. if you do that, the cdi goes into "limp home" mode, and wont let the bike rev over 10,000 rpm in any gear.
