left switch gear playin up lights wont come on help!!!!!
guest
Post by guest »
recently took bike apart to rebuild , put back together now everything works of the switch gear exept the light switch there is nothing. the bike is an import so i think the lights should come on with the ignition the back light does this but not the front. i bought a secondhand switch gear from a breakers , same problem no lights, NOW i brought another switch gear from a breakers which i think is from a uk bike now when you push the hooter button sumin clicks in the relay somewhere an the headlight comes on an u can flick it on an of by pushin hooter button, when u push hooter button in the pass switch acts as the hooter! HELP IM LOST!!!!!!!
methinks you've got your wires crossed somewhere, are you sure you've connected the wiring plugs up right?
guest
bike
Post by guest »
sure i have not got wires crossed checked all that already.could i possibly need to buy a brand new switch gear
