L model fork springs
zxdillan
- My Bike: zxr 400 racebike
could anyone tell me what the standard weight is for the L model fork springs?
kg/mm. got a chance on getting some linear springs but they are .700kg/mm. need to find out what is standard to see if it's worth it. get rid of the progressive standard ones.
- Ballsout Racing
Re: L model fork springs
I think they're 8kgs, nothing really wrong with them except you will probably not use all their travel. Depending on your weight you'll probably need 8.5kgs unless you're a lightwieghtzxdillan wrote:could anyone tell me what the standard weight is for the L model fork springs?kg/mm. got a chance on getting some linear springs but they are .700kg/mm. need to find out what is standard to see if it's worth it. get rid of the progressive standard ones.
thought standard springs were linear anyway ?zxdillan wrote: get rid of the progressive standard ones.
never heard of a bike with progressive/variable springs as stock.
zxdillan
the ones which are in my L2 and L3 are tighter wound at the bottom than they are at the top. which i thought made them progressive? as the more weight transfers to the front under braking the less chance you have from bottoming out because the springs get stiffer, especially when 2 up.
have to admit, i've never had my forks apart, was just under the impression that the stock springs weren't "progressive"
sure yours are the original springs ?
zxdillan
should think so. both bike have been set up with the same sag. 25mm rider sag, preload all the way in. seems strange that both are the same if they had different springs. i havn't changed them.
