jusy got my engine back in n there is a black n yellow wire which connects to the battery and appears again under the petrol tank. iv found a picture on here n from what i can make out its called 'engine ground terminal' can ne1 tell me where this is supposed to go?
cheers doug
where does it go?
DougieDoug
- My Bike: ZXR400L1
where does it go?
have a break, have a kwik kwak
- Scott221
- Restricted
- My Bike: ZXR400 L9
Re: where does it go?
Where the petrol pump sits, under one of those bolts. Don't do it though thill somone else backs me up as I'm not 100% sure what you're on about.
- zxr_oli
- My Bike: Daytona 675
If it's a ground wire, any bit of bare metal should be fine to bolt it onto.
i think the engine needs to be grounded too tho,
Theres a ground terminal thats bolted on just by the fuel pump and another on the motor i think. Just looked through my pics and cant find anything definate for you other than this
I think scott is right tho in that its the bolt underneath the fuel pump, you can see it in the picture but has a black sheath on it. could be black and yellow underneath tho,
DougieDoug
- My Bike: ZXR400L1
i no which 1 u mean that 1s in place. its the wire in ur pic which is sat on the frame opposite the reg with the ring on the end,
aha, that one bolts onto the frame with the bolts that holds the fuel pump bracket in place
DougieDoug
- My Bike: ZXR400L1
ahh thanks for the help will sort that 2day, cheers doug.
