cargo wrote:Team Cargo top tip...........................
When I fit a new gasket I put a light smear of grease on one of the faces.................next time the cover comes off the gasket is usually stuck to the face that had no grease and is nearly always still intact and so can be reused.....................
Zxrworld of tips and tricks....
From Cargo's post on gaskets i thought we could get a collection of top tips together to help fellow zxr owners.So post any useful tips in this thread.(and i don't mean full writeups, create a seperate thread for those.)
- Scott221
- Restricted
- My Bike: ZXR400 L9
Re: Zxrworld of tips and tricks....
If ur replacing brake pads and the piston looks a little rusty, remove the piston, clean it up on a wire wheel, remove the seals, scrape any crusty muck off them and rebuild them with a good smear of rubber grease on the piston and seal faces.
and clean that same crusty muck out of the seal grooves in the caliperScott221 wrote:If ur replacing brake pads and the piston looks a little rusty, remove the piston, clean it up on a wire wheel, remove the seals, scrape any crusty muck off them and rebuild them with a good smear of rubber grease on the piston and seal faces.
with a wire brush on a dremel....cargo wrote:and clean that same crusty muck out of the seal grooves in the caliperScott221 wrote:If ur replacing brake pads and the piston looks a little rusty, remove the piston, clean it up on a wire wheel, remove the seals, scrape any crusty muck off them and rebuild them with a good smear of rubber grease on the piston and seal faces.
Jeppo
Don't eat yellow snow
Glitchard
- My Bike: Kawasaki ZXR 400
Buy Mach 3 razors and a tube of silicone. Take apart the blades carefully until you have about twelve tiny blades. Take 1 Tax disc holder and spread the silicone all over the rear of the holder and place the blades evenly all around the rear of the holder in a star manner. Leave to dry and carefully replace the holder onto your bike. This should stop those people who think it's clever to steal your Tax Disc's instead of buying one.
- Scott221
- Restricted
If you're changing bearings e.g headstock bearings. Put them in the freezer over night. They'll drop straight in rather than bashing the headstock for an hour.
If you're undertaking a big project. Make sure you have a clean space before hand. There is nothing worst in this world than trying to find that 10mm spanner you just had, or that 12mm allen key. You can waste hours until you eventually realise its in your back pocket (yes I have done that
) Keep all your tools neat and tidy, so you know where they are when you want them!
Brake fluid is like paint stripper, if you get it on your fairings, wheels, calipers and/or anything else, get it off as fast as possible. Whipe it off then spray it with water.
brake fluid is also cheaper than nitromors
Dont forget to clean round the back of the fork chrome, left untouched will result in pitting and rusting. Simply take an old rag, poke it round and through in between the mudguard, then pull end each alternately to clean any crap off.
- humanoid1989
- My Bike: kawasaki zxr400 h
Ride your bike regularly!
I didnt for 3 months (i was ill) and now ive got to clean the carbs again!
Sometimes a quick blast, and revving the bike to the redline can clear gummed carbs.
Rev the tits off it- for a bit.
[color=#FF0000][b][i]"Quit your jibber jabber"[/i][/b][/color]
razzcolio
- My Bike: ZXR400L1/VT750C2B/VT600
always ride the right way down a one way street that has a police station on it
- humanoid1989
razzcolio wrote:always ride the right way down a one way street that has a police station on it
And dont play 'Amber Gamber' with traffic lights! Points dont make prizes
razzcolio
ah piss when did that happen? id nearly beat my high score on way to work other day!humanoid1989 wrote:And dont play 'Amber Gamber' with traffic lights! Points dont make prizes
- humanoid1989
I got my maximum tally of points before i got my ZXR. They took my liscense off me, so i had to do it all over again! Apply for provisional, do CBT, re do the theory, and re take my test all over again! Cost alot did that. I even got fined £80.razzcolio wrote:ah piss when did that happen? id nearly beat my high score on way to work other day!humanoid1989 wrote:And dont play 'Amber Gamber' with traffic lights! Points dont make prizes
Im a good boy now!
japmannslim
- My Bike: zxr400l9
It may sound obvious, but always turn your fuel tap to the off position after using the bike. Saves fuel rotting the float valve rubbers. Caught me out!!
