DASH LIGHT BULBS
jack sharpezxr 400 L
- My Bike: kawasaki zxr 400 L
DASH LIGHT BULBS
IVE GOT NO LIGHT BEHIND MY SPEED MY REV COUNTER ONES WORK I HAVE TRIED PULLING OUT THE BULB BUT DOEST SEEM TO WANT TO COME OUT HAS ANY ONE EVER DONE THERES CHEERS
Re: DASH LIGHT BULBS
Im guessing you mean they wont come out of the clock ? Just give the rubber bit a good pull and it should pop out. Just dont pull by the wire. The bulb should then come out of the holder pretty easily.
Take it down to halfords and you should be able to get one the same
- Scott221
- Restricted
- My Bike: ZXR400 L9
saka_ZXR
Yeah i had to replace mine and it came out easily, was only bout 60p for a new bulb
ive tried giving them a tug but just seems like somthings holdin in do you hav to twist it ill try againseems like the wires are gooin to snap im a bit heavy handed so
Dont pull by the wires, youll only pull them out the holder then youll have no light at all.
What might be worth doing it poking a small screwdriver in and try prising it out.
saka_ZXR
U shud just be able to grab the little rubber and pull it out with very little effort, failing that try robs approach or use a small pair of pliers (very carefully) to give u abit more grip on the back end of the bulb.
A little squit of WD40 will help
saka_ZXR
WD40 eh, what wont it fix? :p
