variable cam set up
ratbag56
- My Bike: zxr400 / 636
variable cam set up
When fitting variable cams wot position is a good base setting? and wot valve clearences should there be? (they are kent cams by the way?
Re: variable cam set up
cam timing specs are in the "kit" manual on the main site
http://www.zxrworld.co.uk/Manuals/zxr400r.pdf
