VARIABLE INLET TRACTS / TRUMPETS... IDEAS!!!!!!!!!!!!!!!!!!!
So they dont get muddled and lost in the directory, please post your tuning questions here.
Marcie
My Bike: ZXRS400, CBR600
Post by Marcie »
Hi all, tonight i was watching something about the new R1 and ive been toying with ideas for variable inlet trumpets.
Now i havent seen how yamaha have worked theirs, but i bet its a damn sight more technical than mine.!!!!!
Anyway ive drawn up a crude looking initial idea, and want to get your thoughts, ideas, advice and just generally your opinion!
I mean ive heard of some people putting longer inlet trumpets on the inside two cylinders so we all know that longer trumpets can help the top end, shorter ones for more grunt.
Obviously you would have to get a length that is short enough for grunt but can give good top end too.
So how about keeping the original trumpets, using a wider outer cylinder (so you dont loose volume) fix them to the carbs, once youve fabricated the plastic holder and the rest you can double the length of the trumpets, if the wires are run to the throttle housing slacken them off if theyre coming in too soon tighten them if too late.
Anyway im going to fabricate the bracket etc. Just for fun!!!!
MARCIE! :excited
Some body once told me... Theres only two things in life you'll ever need, Gaffa tape and WD40.
If it moves and it should'nt use Gaffa tape, if it doesnt move and it should use WD40!
Re: VARIABLE INLET TRACTS / TRUMPETS... IDEAS!!!!!!!!!!!!!!!!!!!
I have no idea, but good luck and keep us updated! :D
Marcie
Post by Marcie »
One post... on something that with all our idea's knowledge could be a quick mod maybe giving 5+ horsepower :D
lewisdale
CBT slow
CBT slow
My Bike: zxr400 H2
Post by lewisdale »
if it works well mate u can make me some up providing there not made of gaffer tape n cable ties :pmsl
Marcie
Post by Marcie »
Cheeky ;)
no promises!
hciR
Post by hciR »
I managed to unearth a bit of info on this. See: http://auto.howstuffworks.com/question517.htm
Near the end it mentioned having two seperate intakes with a valve to switch between them. Only problems I can see are the space it would take up, and how well it works with carbed engine (i'd imagine the article is about injection?).
Marcie
Post by Marcie »
Hi HicR,
Read that article, Interesting what it says about the speed of the pressure waves and what not. At the end its talking about diameter of the intake, im talking about length.
Im going to research how velocity stacks work (properly) and report back here.
Thanks anyway
will#224
My Bike: L1 racer
Post by will#224 »
I too have been researching this lately, there is already an ignition module available to allow servo control. You could even go fly by wire if you wanted as per the newer R6. The inlet can sometimes benefit from been a fixed length with a part removed lower down to create turbulant air which could be a simpler option.
Are you looking at this for a race bike? I am and wonder how a club would view this with the recent stop on fuel injection. FCR carbs or standard?
Will
Marcie
Post by Marcie »
Im not looking at this for racing, but its useless on the standard zxr, the air box has no way enough room above the carbs. A possability with a ram air box perhaps??
I scrapped the idea for my bike, and moved on to my mates gsf600, nice big airbox! something for the future.
As for turbulance, sounds like a good idea, If you did it right you would get a variable inlet effect, by that i mean at low revs the air would enter through the higher opening and on full wack, both or the bottom/side opening would draw the air in.
Who wants to hack their stack's up for the purposes of experiment??!! That seems like the new idea, scrap mine unless youve got room and understand pressure waves, which i didnt when drawing up my sketch on paint! :D
Longer means the RPM lowers which increses torque. Shorten the stacks and you get Higer rpm and top end.
Those of you famillia with massimo tamburini will know he created TTS, and that is used on the MV Augusta's, and obviously we are all aware of yamaha's version.
Marcie
