Ignition coil question
Chris1984
Post by Chris1984 »
In the manual it shows the the left ignition coil should be feeding spark plugs 2+3 and the right 1+4 is this important that they are this way as i've just noticed mine are not this way round.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: Ignition coil question
Post by Mori Man »
If the bike is running then NO
but
Normally YES
It's all down to the valve timing / ignition timing. If it had been set 360' out then swapping the electrical leads between the coils cures the problem or swapping the coils - I'd go leads personally as a lot quicker to do :smt002
Do they have after market HT leads fitted ? Although if the originals weren't numbered you could still make them fit running the #1 lead to #4
MM!
Chris1984
Post by Chris1984 »
Thanks for the reply.this is mine.Just seems back to front
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
Don't touch it if it aint broke :smt002
But yeah, originally the other way around.
MM!
