Dont know if anyone wants to have a play with this. Its my spreadsheet for doing all the working out
type in the measured gap at the top, and the current shim size and it works out the replacement size.
The given replacement size isnt in 0.5 increments, so you need to put in the actual replacement size being the nearest 0.5mm increment, that then works out your new gap, that allows you to try the nearest values and get the gap you want without having to work it all out again on the calculator, just type it in.
I did try to add the file itself but .xlr extensions arent allowed, so ive shown the formulas that you need to write in the spreadsheet, about 10 mins work
