Polishing ,whats best way ?
BrianZXR
My Bike: zxr400h2
Post by BrianZXR »
Am giving serious thought to spending a month with bike off the road to clean it up , have polished little bits of bike as ive gone through it , but have found that nitromors struggles to bubble the paint on the aluminum , is there anything else that will work abit better ? , i expect to apply alot of elbow grease to get it how i want it , also is there a product that i can coat polished frame in to stop it greying ? thanks
Re: Polishing ,whats best way ?
Post by SOILZX »
I personaly remove the paint (either nitromors or sand it down), then go over it with fine paper (1500-2000 grade) with a cutting compound, then get some polishing wheels in a battery drill, apply cutting compound to area and go over with wheel in drill. Clean up after with brasso and a rag and/or polishing wheel again.
Theres proably easier ways, this just how i do it, would be quite interested if others have a different way round it??
Regards
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
ask this guy.
Post by SOILZX »
:pmsl :pmsl :pmsl :pmsl Why didnt i think of that!!!! WAX-ON, WAX-OFF!!!! Classic!!
Brian, ive just come in from the shed doing exactly that. Having a brew thinkin ...whats that powder coaters number again....
I used the nitomours, it does get a bit of it off.. but i know what you mean, it does struggle. I then got a wire wheel on my cordless and got the rest off. Then as soilzx does, get busy with the wet and dry. Then get the polishing wheel and wax on it.
I kinda gave up with the super mirror finish idea, and went for the slightly shiney.
The only tip i can give, wrap something soft around the drill chuck when polishing, as the drill will jump off the work and dent the ally vsad
Post by SOILZX »
"The only tip i can give, wrap something soft around the drill chuck when polishing, as the drill will jump off the work and dent the ally vsad "
Ye, pissed me off, so i stopped using the dewalt cordless (metal chuck) and used my Mac tools one (plastic chuck), problem soleved :smt003
will#224
My Bike: L1 racer
Post by will#224 »
i've just done the frame, its now a brushed ally finish, the swingarm was a pig though and i got it shot blasted, the welding on the swinarm is also now brushed ally finish, crap welding the swingarm though!!!
BrianZXR
My Bike: zxr400h2
Post by BrianZXR »
cheers ,i have been using course wire wool grading down to fine with nitromors and then 1200 paper and autosol and then a bar towel with autosol , comes up good ,but soon as you touch it theres a mark , anything i can coat it with to keep that shine for longer ?
Post by SOILZX »
you could lacquer it, but you would have to get the right laquer to etch to the bare metal, other than that i think you toad out mate to be fair, i'm having similar troubles with mine, but i find it is better when i go over it with a rag and some brasso (whether it actually is, is another matter, proably just wishfull thinking :smt002 )
when i built the streetfighter i polished the wheels by stripping with nitromors and 3 grades of wire whool then used a polishing kit from here 3 grades of abrasive wheel then 3 grades of mops/soap.good finish but you gotta keep on top of it.Laquering polished alloy will turn it a yellow colour.
Keeping polished alloy shiny is a pain in the ar5e..............................There was once a time when Jap bikes came with lots of exposed polished alloy Looked good when you bought it new in the shop but very very soon it was not so shiny..............
I used to cover any exposed alloy on my KH250...............with vasiline for the winter looked awful but I knew that underneath that mess was a shiny bike. Come spring and a bucket of hot soapy water the shine was restored..............mind you the alloy in those days was more like cream cheese. :pmsl
Wife's ER 5 has lots of polished alloy...................................I never touch it................her job if she wants it shiny
will#224
My Bike: L1 racer
Post by will#224 »
I go for the brushed ally look using abrasive pads, scotchbrite or york abrasives make them
BrianZXR
My Bike: zxr400h2
Post by BrianZXR »
yes was wondering if a light coat of clear grease would slow it down , frames and swingers look the goats gonads polished ,got work with-in walking distance for the next few weeks so might strip it back and give it a whirl ,will let you know how i get on , thanks
For a while I helped keep the wifes bike shiny with a tin of silicon spary..................she thought I was polishing and cleaning it...................I just sprayed with the silicon.
Dealers use it to make second hand bikes look shiny in the showroom
try some alu belgom rather than autosol, less harsh and lasts longer.
