You will need " Far Eastern " language pack installed into your windows - go into control panel and select languages, you will get an option. Otherwise your going to see a pile of ???//???!!!#/?111?/"###1/
This is a rough guide to stear you in the right way so is not definitive. What it will let you know is if there is still factory stock. On the parts list page you can directly input numbers if you know them so you can check UK parts or any world wide code.
You might be able to call up a Microfiche for your bike if you use the frame number - never tried it. If a import was brought into the country they list them so you do find english for some models - most are from Malaysia.
When you get the Yen price you will see two prices - the cheapest is with out 5% tax
Your not going to save buying piddling amounts or a few fasteners but will save on larger or a fuller order compared to UK/Europe prices.
http://www.kawasaki-motors.com/for_users/partscatalog/
Start here
