For my EFI system I need to have a high pressure fuel pump and I am stuggling to find one that doesnt fit into the tank, so was wandering if any newer bike's tank will fit? like an injected ZX6r? anyone got any ideas? cheers
dan
Fuel Tanks
- carsounds_dan
Fuel Tanks
...i know, it's great
Re: Fuel Tanks
With abit of work you can fit most things to..most things! take it you'll be running the ZX6R air box as well? if so it would probably make life easyer using a 6r tank as well
- deviant
- My Bike: ZXR400 L3
Re: Fuel Tanks
Buell? I doubt they manage to fit the fuel pump into the frame, so it must be external
- Ballsout Racing
Re: Fuel Tanks
Why not fit one into the tank
or am I missing something
- deviant
Re: Fuel Tanks
I'm guessing because he doesn't want to cut into the tank...
- carsounds_dan
Re: Fuel Tanks
bingo I don't want to cut the tank.. I want something cheap to work on though as I don't want to splash out a tank and pump for a new zx and it end up not working lol
cheers
dan
cheers
dan
Re: Fuel Tanks
noobie question, but why fit the fuel pump in the tank? Whats wrong with having it externally?
- carsounds_dan
Re: Fuel Tanks
nothing wrong at all but I need a high pressure pump for the injectors to run off and i'll be buggered if I can find one that will mount outside the tank
Re: Fuel Tanks
I see, thought there was some reason that fuel injection needed it inside the tank.
