I did 3 laps last night 2 on the 600 and 1 on the 400
The second session was cut short because of the failing light.
Only minor problems to sort out with the bikes the 600 was undergeared and the clutch was slipping a little.......................the 400 had a very stiff throttle action I suspect that it's something to do with the new twist grip I fitted..............the 400 might just pull a tooth less it was right in the red for miles and miles..................... lovely. Then again thats what a zxr400 is for
