1. No TPS
2. No Choke
and as suspected both these items are missing on the Bito set. However there are plenty other differences too
Lets start at the top,
Needle is held in place with an Allen key plug and not a flat head screwdriver type.
Needles are brass and not the coated aluminium ones in the SP's. (Different code as well)
Screw in billet inlets instead of cast
Throttle valves are stamped differently
No fuel rail by-pass line
Easy access for changing main jet
Kick ass decals
Kick ass MJ's
All jets are completely different , MJ is 50% larger in the Bito's
Anyone want a set of SP carb's - got to get myself a set of these puppies
