I have taken off the 4 black plastic covers (i think its a vacuum cover) and removed the jet needle. I have also removed the back of the fuel bowl and removed the main jet and the needle jet holder, i will remove the pilot jet tomorrow when i have got a thinner screwdriver.
My main questions are...
1. can you remove the main air jet and pilot air jet like on the H-model? I dont think you can, but if you could what would changing the sizes achieve?
2. can i now clean the carb assembly in a sonicator? i was going to use acetone/carb cleaner, but i dont know if the bits of plastic (like the fuel "rail" etc... will survive acetone/carb cleaner? I have not split the carb bank into individual carbs because i have been told it wil be very difficult to put them back together, is this correct and would they clean better if fully dissassembled.
3. do i need to remove anything else (like the pilot screw) to fully clean all parts of the carb?
4. the main jets have '116' stamped on them, i assume this is the size (i.e. L manual says #95installed at factory), but how do you know what size the a) 'jet needle' b) 'pilot jet' and c) 'needle jet holder' are? i dont seem to have any markings on mine.
5. my jet needle had a small clip on the 3rd indent from the tip of the needle, and had 3 shims on top, what should the stock settings be, cant find them in the manual/microfiche?
6. any other hints/tips you can give me?
7. thanks
