I am currently restorring a Zxr400L1. I bought it cheap from a breaker, not knowing the history/condition of the bike.
I just fitted a new CDI, new spark plugs, new fuel and air filter.
Cleaned the carbs the other day.
I then mounted the carbs, pulled the choke lever to fully engaged and pushed the starter. When the carbs were filled, the enginge started instantly.
But during warm-up the engine cycles alot up and down, from 1000 to 4000rpm. It dies when i use less than 3/4 choke. When i turn the throttle it dies unless i let go of the throttle.
S0.. i am convinced the problem is relating to the carbs. But where do i start?
air screws are set to 2 1/4 and 2 3/4 from full in. Haven't touched them. Needles are standart and clean, they move freely up & down. Jets are clean.
Hope u can help...
