Bikes not running so good just now so I've opened the carbs to find that some of the spacer washers have fallen of the top of the needle, does anyone know if this should make a difference? As far as I can tell they only hold the sping tighter so shouldn't affect the air fuel mix.
Does anyone have a good set up for Dyno-jet i.e what notch to put the spring clip on and so on ?
The bike still has the standard exhaust, don't know if this affects it or not.
Dyno-jet
- greengoblin
- My Bike: 96 ZX7R, 01 ZX6R
sloweracing
You will need to dyno or play on the road but the height of the needle will make a difference to the fueling
the washers are they under the circlip on the needle and is the needle at the lowest point now
the washers could be to just put more tension on the spring but you shouldnt need them but wouldnt like to say
As you take the top off the carb turn it upside down does the washer fit over the plastic lug where the spring would locate so is it a big washer or small washer dynojet do a washer for there needles but fits over the main needle so there would be 4 off them to place under the circlip just so it sits nice
Good luck
Good luck
- greengoblin
