Radiator leak
bullet719
My Bike: zxr400 1996
Radiator leak
Post by bullet719 »
Was riding and noticed steam/water(coolant) spraying out of the top left of the radiator. And idea what my next step should be? Haven't had the opportunity to look her over as she is stuck at work. Reluctant to ride home in fear of damaging something.
Thanks.
(1994 L model)
Sent from my E6653 using Tapatalk
Miles
My Bike: ZXR 400 L3
Re: Radiator leak
Post by Miles »
Definitely a hole in the radiator? Could be a split on the lhs hose.
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Re: Radiator leak
Post by banner001 »
Top left when your sat on the bike is probably a leak, top right of you were facing the front of the bike could be from the radiator cap.
You need to wait till your bike cools down, top-up.the expansion bottle and the radiator and run your bike back up to temperature with your side panels removed. This will give you a clear indication of where the leak is coming from.
If you're close to me I'll come down and check it out for you
bullet719
Re: Radiator leak
Post by bullet719 »
banner001 wrote:Top left when your sat on the bike is probably a leak, top right of you were facing the front of the bike could be from the radiator cap.
It was definitely top left when sitting on the bike.
Where abouts are you. I'm based in Bromley (south London).
Matt
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Re: Radiator leak
Post by banner001 »
Probably a rad leak then, possible to get them plugged, if it's bad or all the aluminium is really corroded then it's new rad time, if it's the body of the rad you might be able to get it filled or welded by a damn good welder.
I'm in nuneaton in the Midlands, I can come to you but would need petrol covering and that's about £35, so use me as a last resort.
