coolant coming out overflow update 26/10/13 HG time ??
spudboy6
My Bike: zxr400 L-9
Re: coolant coming out overflow update 26/10/13 HG time ??
Post by spudboy6 »
Cheers ross46 , your the chap selling the gaskets aren't you ? Can I get a pulse cover gasket of you ?
Right started getting on with it earlier an took the pulse cover off to see how the chain is looking and my god wish I didn't
Chain is on max adjustment , so chain needed (tensioner can be reset ? )
And found a half moon almost like a staple in there :(
What's that ? Pic to come
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
:ffs
ross46
My Bike: zxr 400 l6
Post by ross46 »
That doesn't look like the tensioner, I think that is an actual staple confuddled and send me your address and send the money to ross_46@hotmail.co.uk and I'll get it sent tomorrow for you
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
Cheers pal how much do I need to send you ?
Yea it looks like a staple to me , I recall a thread a few pages back with the part that was a half moon sat in the case but his was much thicker.
How would a staple get in there :smt017
ross46
My Bike: zxr 400 l6
Post by ross46 »
The pickup The oil is magnetic, could have picked it up somehow? And £4.50 for the gasket
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
Cheers ross46 money is sent
Will try and have the engine out tomorrow and get it stripped
To get the forum discount at cradley do you have to ring them or can you get it online ?
Am I the only one who has noticed that the tenioner is fully maxed out?
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
Few posts up I've stated its having a new chain and I asked if the tensioner can be reset but didn't get an answer
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
spudboy6 wrote:Few posts up I've stated its having a new chain and I asked if the tensioner can be reset but didn't get an answer
Yes it can. you have to compress it and get a paper clip or that staple you found and shove it in the hole before refitting the CCT.
Once fitted pull the pin / staple out and the CCT snaps into place.
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
Okay thanks for that I wasn't sure how it was done as I've read about some being a ratchet design or is that older ones ?
I'll get on with it over the next few days when I get to the tensioner does it need removing from the case at all to compress it or should I leave the bolts alone on the outside ?
I'm sure when I get on with it will all make sense
ERRRRRRRRRR ~NO
the tensioner in the pic is the upgraded one...........tension is applied after fitting the body when the springs and bolt are replaced
the staple is interesting....................HTF did it get in there.......
Am I the only one who has noticed the metal filings on the left pick up bolt ??
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
Yea I've noticed the filings very un-nerving what I came across when I took the case off , will just have to remove and inspect parts as I go along and see what I find
I noticed the filings too....
ross46
My Bike: zxr 400 l6
Post by ross46 »
Seem to be fairly common in pictures that ive seen, probably not seen in race engines or ones that are looked after, first time I took pulse cover off they were there, but since I haven't seen them, regular oil changes probably helps, never many filings in the filter which I cut and check every oil change. They could just be getting stuck there, thats the idea behind magnetic sump bolts. And spudboy6 I got your mobey but need your address to send the gasket.
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
Took the head off and found this looks like detonation , bores are un-marked and compression test before hand on no4 was good
So can this piston be re-used ? I've checked with a flat edge the head isn't warped and I think it will need a skim to remove the imperfections but what's caused this damage and how ? I had a spark plug snap not long ago in no4 but I have 3 damaged parts of the head near the valves
Would you reuse this piston ??
