oil cooler blanking plates??
Jackh2
My Bike: zxr400 h2 1990
Post by Jackh2 »
Want to remove the oil cooler and bin it because it's in Bad shape, dose anyone make blanking plates for the bottom of the sump, or done this? / made their own?/ got a solution. Thanks in advance.
Ewetea
My Bike: ZXR400L5
Re: oil cooler blanking plates??
Post by Ewetea »
If you type "oil cooler blanking plate," in the white "Search" box with the magnifying glass at the top right hand corner of the header, then you will find a number of opinions. You can then make your own decision.
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
What some people do it use one of the oil pipes that go on the oil cooler in place of the oil cooler....
There is an oil flow diagram in the manual......................it's most revealing
CaNsA wrote:What some people do it use one of the oil pipes that go on the oil cooler in place of the oil cooler....
thats what ive got on the track bike...ive got the side panels off at the moment, if i remember ill take a picture.
Jackh2
Post by Jackh2 »
Cheers for the help guys New on this forum appreciate your time to reply
alanh
My Bike: zxr400 L racebike/R1
Post by alanh »
i just had the holes in my sump for the oil cooler welded up. worked fine for a trackday at donnington and 10 races plus quali/testing without exploding. on my old engine i used the original pipes, cut the pipe right down and squashed the ends then welded them, worked ok but welded over looks neater and shouln't corrode like weld will
ross46
My Bike: zxr 400 l6
Post by ross46 »
"welded over looks neater and won't corrode like weld will" :smt017
alanh
Post by alanh »
ross46 wrote:"welded over looks neater and won't corrode like weld will" :smt017
haha yeah should have been a bit clearer than that :smt005 welding over the holes in the sump (ali welding) looks much neater than having the original steel pipe folded/welded and the welded sump wont corrode like the welded steel pipes will.
took me a while :D
ross46
My Bike: zxr 400 l6
Post by ross46 »
Looks like that bike needs a clean!
not only does it need a clean that is frankly a ludicrous solution to a problem that does not exist
its temporary until i get some blanking plates cut (soon), it allows me to use the bike in the meantime :wanker
cargo wrote:not only does it need a clean that is frankly a ludicrous solution to a problem that does not exist
sigh, are you gonna jump on these people as well cargo, some even posted about doing what i did in some of your threads...and you said nothing to them...i assume you are being a :wanker towards me, because you still secretly :smt007 me...
viewtopic.php?f=37&t=14370&hilit=cooler#p107388
viewtopic.php?f=37&t=11271&p=89788&hilit=cooler#p86892
viewtopic.php?f=37&t=10160&hilit=cooler#p83059
viewtopic.php?f=37&t=5392&p=44149&hilit=cooler#p44042
...i could go on...
Flatowtornowt
Post by Flatowtornowt »
could a possible solution be to tap both holes and put bolts straight in with copper washers ie the same idea as the sump plug?
