cam chain mystery, now gearbox new thread
richr
Post by richr »
hi all
now here is a quandry to be solved by you good people here present :smt003
i replaced my cam chain and tensioner some months ago but i havnt ridden the bike as im getting it ready for track days
anyway i did the replacement all as specked and engine was fitted back into the bike i ran the engine and all was honkey dorey, so today as it was nice thought ill just run the bike for a bit as work is still in progress.
so starts bike allows it to warm up and on overun the chains a bit noisey the the strange bit lean the bike to the left and it sounds like the chain is rubbing on something stand it upright it all goes quiet
ive pulled the side cover off and taken the rockerbox off but cant see anything wrong, ive also put it into gear and turned the engine over using the back wheel and all seems good
swmbo says just ride it on righthand turn tracks but i cant see that happening some how
any help mucho appreciated
richr
Re: cam chain mystery
Post by richr »
looks like ive got every one stumped on this then :smt010
wheres cargo when you need him :smt003
Sure its not the clutch basket you can hear? Leaning the bike to the left will drain the oil to that side, and the clutch side will effectively have less in it, perhaps making it noisier??
Other than that ive no idea what sould be making it noisy, is the tensioner plunger set low down or is it quite high? That would be my gauge as to much adjustment is left on it.
richr
Post by richr »
thanks for the reply rob
i did wonder if it was the clutch, only after i pulled the top off :smt010
its a new chain and tensioner and the tensioner has plenty of travel left on it.
i cant see anything obvious with the limited space to look into where the chain is.
think i may have to put it back together and start her up again.
regards rich
richr
Re: cam chain mystery, now gearbox new thread
Post by richr »
mods
this thread can be locked if required as i have started a new thread as it appears to be a gearbox problem :smt010
