can someone tell me if there is some magical way of fitting the clutch casing
my lads h model casing was leaking from a crack around one of the bottom bolts at the rear of the casing
he got a replacement off ebay that looked ok so i fitted it today and guess what cracked and leaking from the same bolt and from one at the top as well
![:smt017](./images/smilies/017.gif)
is there some kind of black magic voodo to fitting them or is this just bad luck and no i didnt over tighten (9.5 nm) used sealer and nipped up opposite bolts same as with torque wrench
im relly p*ssed off with it
![vsad vsad](./images/smilies/icon_e_sad.gif)
ive put a wanted add on the forum if any one has one pm me please
