head port
- My Bike: zxr400
head port
hi guys can you help, ive got a leak coming from the top of the head i think.
ive removed engine and found a hole under each head port for exhaust and there seems to be oil coming from there as well, does anyone know what these holes are and if oil is coming from there were is it coming from.
Re: head port
The four small holes are drain holes for each spark plug reccess........................and if the is oil coming from the holes then oil is leaking into the spark plug reccess
simples
simples
- My Bike: zxr400
Re: head port
hi cargo so is it the seals around the top of the spark plug recess inside the rocker cover that have gone cos all spark plugs are dry.
or is there a more serious problem cos bike runs fine
Re: head port
What Cargo said - likely some one removed the wells doing a shim check but didn't put new O rings on - they are one use only so replace every time you disturb.
- My Bike: zxr400
Re: head port
cheers for that mate will purchase some new ones and fit them
Re: head port
MM is talking about the o rings at the bottom of the spark plug well/recess
I would reuse the top seals and apply a little sealer
- My Bike: zxr400
Re: head port
do u mean the o rings on the spark plug trumpets (if thats you call them) when you remove them there is a o ring around the bottom of these trumpets.
Re: head port
mcollier wrote:do u mean the o rings on the spark plug trumpets (if thats you call them) when you remove them there is a o ring around the bottom of these trumpets.
That is the ones you should replace.
Re: head port
Part # 92055-1403 x 4 about a fiver here for them so expect 2 quid each UKmcollier wrote:do u mean the o rings on the spark plug trumpets (if thats you call them) when you remove them there is a o ring around the bottom of these trumpets.
- My Bike: zxr400
Re: head port
cheers for your help again new ones fitted
Re: head port
That the oil weap sorted ?
Bikes looking real good![:smt023](./images/smilies/023.gif)
- My Bike: zxr400
Re: head port
cheers again for valuable advice all sorted.
