Timing gear one unit on the crank?
Animammel
My Bike: ZX400 G
Post by Animammel »
Teeth broken on the gear, do I need to replace entire crank or can it just be replaced. never mind monkeys, looks like zebras worked on this motor.
Dont want to strip down everything for no reason.
_____________________________ viewtopic.php?f=87&t=14464 _______________________________
Re: Timing gear one unit on the crank?
ive not examined mine that closely, but i thought that most cranks were machined from a solid lump of metal, if thats the case then you wont be able to remove the timing gear.
i would be worried about where that lost tooth is, and i would guess that a new engine might not be a bad investment considering the possible cost of stripping and rebuilding your current lump?
I think the sproket might be machine pressed on? No idea about replacing the sprocket. Im sure ive seen whole cranks on ebay so might be worth a look.
Animammel
My Bike: ZX400 G
Post by Animammel »
Pistons fine, barrel very good, just bought new head. Stuff is adding up, I will have a look see.
I hope this is the last bit of cash spent as its gonna be a 2 minute noodle month as of now.
Thanks guys
