i have a l1 with a noisy cam chain i have looked at the tension and all seems ok , upon more inspection it seems like the chain on the exhaust side seems more slak than the intake side is this normal ? Im also not sure on were the chain guide on the exhaust side goes as you can move this up and down
, if i move down as far as it goes the chain is slak ( only on exhaust side ) . If i move half way then the chain is tight as on the inlet
hope this makes sense
thank kev
