So my zxr is my first ever road bike. I've only ever ridden/raced motocross bikes. Generally i'm used to a very very light snappy throttle action, whereby I could comfortably twist the throttle with my thumb and forefinger easily and it would snap back closed.
When i picked up my zxr my first feeling was that the throttle action was quite tough and jot snappy. It returns fine but it's definitely a heavy throttle so thought it might need new cable, lubricating etc but as i've never had a road bike before I have no idea what is or isn't normal. So how smooth and light should the throttle actually be?
Throttle snap back
Re: Throttle snap back
Make sure your grips aren't catching on the edge of the bar, or it may just need the throttle tube taking off and cleaning. I'd try the easy (and free) things first
- Miles
- My Bike: ZXR 400 L3
Had a sluggish throttle on mine.
Strip it to bits, clean everything. Check that your grips arent rubbing on the controls ie catching. Seen this on heated grips cause their thicker so they rub against the controls.
I then checked the throttle cable routing and dripped some oil down the cable. Working it back and forth until the clean oil was coming out the other end. Wiping the gunk that came out with a cloth.
Finally, and what made the biggest difference for me, I cleaned the spring mechanism on the side of the carb. Opening and closing it whilst spraying wd-40/brake cleaner/carb cleaner into it and again cleaning the gunk that came out.
Check your return cable as well
