I had a silly off few weeks back and changed the gear pedal assembly, could it be related to that, i checked the linkage it seems fine...? or is it clutchy problems? help please... Im in greater manchester if anyone wants to give a hand
exactly what I was gona ask now, but youve just replied, as I had to reconnect that to the new assembly and wondering have I got it wrong somehow. Is there a set length or a correct method of fixing it?rene wrote:id start with checking the linkage (the rod from the gear select to the gear box) check that its not overly lose, or tight
