mornin all, haveing a spot of bother with my lil h2, as you all know i brought a duffer the little ends have gone, but now im haveing this problem.
what is the best way to go about reinstalling the conrods and pistons back onto the crankshaft???
cheers rob
reinstalling conrods and pistons
- toykaboy
you bend it you buy it!
- Harvey Wishbone
- Harvey Wishbone
If you have the con-rods attached to the crank already, it can be a bit of a git to get all the pistons into the bores because of the rings. Try turning the crank, so 2 and 3 pistons are at TDC then slide fiddle struggle and swear trying to get those in first, then get an assistant to slowly turn the crank while you hold the cylinder, stopping the two piston you have in the cylinder from popping out, do the same to the outer pair and after much swearing sweating and many cups of coffee, it should be done!
Oh, and don't forget to thread the camchain through it's slot!
ZX6R G2 roadbike, Suzuki GSXR 600 trackbike
